Zabbix deployment best practice
  • CarlosTech
    • Aug 2017
    • 20
    hi all,
    I'm new to the forum and new to Zabbix in general. Have heard and read a lot about how great Zabbix is but never had the opportunity or need to install it (used PRTG at my last place)
    However i'm in need of a monitor in my new place and Zabbix is top of the list. I've had a search through the previous posts but cannot seem to find anything telling me what the best practice is on setting up Zabbix... what i mean by this is:
    having a database server separate to the Zabbix application server?
    we're a very small setup potentially growing, so currently i've got approximately 100 - 120 devices to monitor (ranging from switches, to servers, workstations etc.)
    i'll be monitoring the usual, memory, CPU, up time etc. so i don't anticipate having huge amounts of data.
    from what i've been reading my plan was to setup the following:
    -MySQL server (Ubuntu, 4GB ram, 120GB drive, 2 core single CPU) - VMWare VM.
    -Zabbix APP / Front end server (same spec as above)
    My train of thought is that i don't want the DB server side of things impacting the Zabbix app / (performance wise) front end and also if something happens to the latter the DB is still intact (and separate per say)
    Thanks in advance
    C.
  • LenR
    • Sep 2009
    • 1011
    We went through this discussion in the 2.x era, but I don't think it's changed much. Our systems:
    • Zabbix "node" consisting of mysql and zabbix server, monitor as little as possible here
    • Zabbix frontend web/php, even more than one if you want to load balance
    • Proxies for monitoring, 5 large ones, some small for network access
    5300 NVPS, Database is 3.2Tb, Zabbix servers are VM's.
    • bbrendon
      • Sep 2005
      • 873
      You're in vmware and you have a small environment. Just start with one server and scale out if necessary.
      You'll probably need more than 4gb of ram though right off the bat.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • CarlosTech
        • Aug 2017
        • 20
        thanks guys, got Zabbix installed and running as a trial on a single server.. will see how it goes.. but may well look as separating the solution for the prod environment.
