Template for KONICA printers
  • vedranOP
    • Sep 2015
    • 12
    I need template for following devices:
    Konica bizhub C220
    Konica bizhub 283
    Anyone can help me with specific or universal template for this devices.
    I would like to monitor consumables.
    Cheers and thank you in advance
  • onallion
    • Mar 2016
    • 131
    The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
    • vedranOP
      • Sep 2015
      • 12
      Thank you, did an update to the template names inside to make it work.
      Unfortunately, template is missing the most important info: consumables.
      • BayramGrbz45
        • Sep 2020
        • 16
        Hello.
        I can no longer find your printer template that I used before. Is it possible for you to share this teplate with me?
        Thank you.
        https://web.archive.org/web/20200920...inter-template
          Just in case in this thread too...
          Zabbix share is no more. Related items should be available from https://github.com/zabbix/community-templates
