Zabbix – Are APIs mandatory to automate trigger dependencies?
  • user.unkwown
    • Jun 2026
    In a multi‑site Zabbix environment, I am setting up trigger dependencies to reduce alert noise (network → hypervisor → VM).
    My question is simple:
    Is the Zabbix API mandatory to automate the creation of these dependencies when new hosts are added,
    or are there native mechanisms (templates, auto‑registration, built‑in rules) that allow this without using the API?
    The goal is to avoid any manual configuration at scale.
    Thanks in advance for your feedback.
  • tim.mooney
    • Dec 2012
    • 1437
    You can encode the dependencies at the template level. That's what I did when I first deployed Zabbix at my workplace many years ago. Templates can be applied as part of the discovery process or manually, depending upon what makes the most sense for your environment.
    You will likely end up with some template proliferation, though. Unless you find a better way than I did, you'll likely have a "Datacenter A Base system", "Datacenter B Base system", etc.. Any add-on templates ("Datacenter B Domain Controller") may require a per-datacenter template copy too. My environment has a primary datacenter and two smaller off-shoots, so I only need a copy of a non-base template if we deploy some service in datacenter B or datacenter C. Cloning templates and tweaking a few triggers eases the process some.
    It's worked well for my site for more than 10 years, but I wouldn't call it perfect.
    • irontmp
      • Sep 2023
      • 99
      You will likely end up with some template proliferation, though. Unless you find a better way than I did, you'll likely have a "Datacenter A Base system", "Datacenter B Base system", etc. Any add-on templates ("Datacenter B Domain Controller") may require a per-datacenter template copy too. My environment has a primary datacenter and two smaller off-shoots, just like how super 7 casino manages multiple platform environments smoothly, so I only need a copy of a non-base template if we deploy some service in datacenter B or datacenter C. Cloning templates and tweaking a few triggers eases the process some.
      Zabbix native templates and auto registration can handle basic dependency automation when hosts follow a consistent pattern. Any host linked to a template will inherit its trigger dependencies automatically. However for cross host dependencies like network to hypervisor to VM the native mechanisms fall short since they cannot easily define relationships between different hosts. For that level of chaining at scale the Zabbix API is pretty much necessary. A script triggered on host registration that automatically creates dependencies between related hosts is the cleanest solution for a truly scalable setup.
