web checks from client
  • zdenek
    • Aug 2017
    is there a way to setup Zabbix to check availability of a web service from agent installed on a client? I have a server (with agent installed) that depends on a certain webservice published in the Internet and I want to check if the service is available from that server/agent. Not from the zabbix server itself...
    Thanks for the info
    Zdenek
  • kloczek
    • Jun 2006
    • 1771
    Just install proxy in any point in network from where you want to probe over web checks.
    • LenR
      • Sep 2009
      • 1011
      I experimented with an apache proxy on a cloud vendor, configure zabbix to check the proxy, configure the proxy to forward to what you want tested. It worked, but I didn't need it in production.
      You could use a userparameter that calls a script
      You could use a script and zabbix_sender
      Like others have said, you could use zabbix sender.
      • kloczek
        • Jun 2006
        • 1771
        BTW proxy. Do you know that in each web check item you can enter proxy details?
        • zdenek
          • Aug 2017
          thank you for you replies. I will try to install proxy on the host
