*unknown* ??
  • lou.degenaro
    • Jul 2017
    *unknown* ??
    My trigger's expression is:
    {testducc:web.test.fail["[testducc] DUCC"].last()}>0
    The e-mail sent by Zabbix contains:
    testducc: DUCC status
    Trigger status: OK
    Trigger severity: Warning
    Trigger URL:
    Item values:
    1. Failed step of scenario "[testjducc] DUCC". (testducc:web.test.fail["[testducc] DUCC"]): 0
    2. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
    3. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
    Why do I get 2. and 3. *UNKNOWN* and how do I get rid of them!?
    Thanks.
    Lou.
  • LenR
    • Sep 2009
    • 1010
    It's from the default message in the action, the default is to send the first 3 item names and values, since you only have 1 item, the others are unknown.
    You uncheck "use default message" and just delete the parts for items 2 & 3.
    I suggested for actions, "unknown" be null, then the message would self configure to the number of items, but I either didn't explain it well enough or no one else likes the idea :-)
    • lou.degenaro
      • Jul 2017
      Not sure I understand.
      Under Configuration -> Actions I select my action's Name and go to a new page that has boxes for: Name, Default subject, Default message...
      For Default message I see 3 entries:
      Item values:
      1. {ITEM.NAME1} ({HOST.NAME1}:{ITEM.KEY1}): {ITEM.VALUE1}
      2. {ITEM.NAME2} ({HOST.NAME2}:{ITEM.KEY2}): {ITEM.VALUE2}
      3. {ITEM.NAME3} ({HOST.NAME3}:{ITEM.KEY3}): {ITEM.VALUE3}
      Original event ID: {EVENT.ID}
      I deleted the last two and Updated and now see this:
      Item values:
      But when I force the event I still get e-mail with:
      1. Response code for step "Home Page" of scenario "DUCC Web Server". (bluejws67:web.test.rspcode[DUCC Web Server,Home Page]): 0
      Original event ID: 370
      Thanks.
      Lou.
      • LenR
        • Sep 2009
        • 1010
        Ok, check to see if the action's operation that sends this message has "Default Message" checked. If not, you have to edit the message in that action.
        Also check the default message to be sure it's saved as you intended.
        • lou.degenaro
          • Jul 2017
          No joy.
          Please see attachment.
          • LenR
            • Sep 2009
            • 1010
            Post the Operation section that sends the email
            • lou.degenaro
              • Jul 2017
              Problem solved: user error
              Turns out there were 2 Zabbix servers running each on a different host. I had thought one of them was retired, but it was still running. Enough said.
              • LenR
                • Sep 2009
                • 1010
                I call that "Dead Armadillo" debugging, sometimes you just have to stand in the traffic and see which way it's going....
                • louis-m
                  • Nov 2013
                  • 70
                  I normally create a TESTING alert and place a load of variables eg Item Value 2 = {ITEM.VALUE2} in there under a heading of For debugging Only.
                  The default alert only gets the values I know it needs eg {ITEM.VALUE1} etc
                  If testing, i temporarily disable the live alerts (to all admins etc), enable the test alert (only to myself) and then when the message comes through, I can see what variables it's chucking through with it.
