Trigger on "average" but exclude spikes.
  • detniels
    • Jun 2026
    I am sampling some data every 10 seconds and wan't to trigger when all of the sampled values have been above 5 for a duration of 5 minutes.
    Average doesn't help me, maybe because I am too dumb to use it.... But if all values returned during the 5 minutes are 1, except one value that is 100, the average trigger will fire, obviously.
    What trigger function should I use?
    (Zabbix 6.0.5)
  • detniels
    • Jun 2026
    I have tried using percentile()
    But I don't understand why it triggers on this data:
    Click image for larger version  Name:	image.png Views:	0 Size:	45.1 KB ID:	514140The expression is:
    percentile(/LO - Windows Server/perf_counter_en["\PhysicalDisk(_Total)\Avg. Disk Queue Length"],#30,100)>5
    And as far as I can understand, all values returned during that last 30 samples have to be ABOVE 5 for the trigger to fire?
    But it still fires and creates a problem.
    • detniels
      • Jun 2026
      The items collecting the values is this:
      • detniels
        • Jun 2026
        Trying this trigger:
        percentile(/LO - Windows Server/perf_counter_en["\PhysicalDisk(_Total)\Avg. Disk Queue Length"],300,95)>=5.0
        also doesn't work as expected (from my understanding)
        Viewing the corresponding graph, no values returned are above 5 in the 5 minute graph, so why does the trigger fire and create a problem?
        • kyus
          • Feb 2024
          • 210
          You can use the min function.
          min(/LO - Windows Server/perf_counter_en["\PhysicalDisk(_Total)\Avg. Disk Queue Length"],5m)>5
            • 5002
            yep.. min() will help you. All values during calculation period have to be higher than your desired level to be triggered.
