How can fix template to get correct writeKB/S for each disks
  • bab
    • Aug 2020
    • 197
    I am using follow template :
    Zabbix template for collecting IO statistics. Contribute to grundic/zabbix-disk-performance development by creating an account on GitHub.
    to find out amount write KB/S on disks but for example my virtual machine has 1 disk (sda) and it contains volume such as follow :
    /dev/mapper/vg00-root   /                       xfs     defaults        0 0
    /dev/mapper/vg00-backup /backup                 xfs     defaults        0 0
    UUID=154dc742-6137-43bc-acae-d9e3e198b93c /boot                   xfs     defaults        0 0
    UUID=2554-72EE          /boot/efi               vfat    defaults,uid=0,gid=0,umask=077,shortname=winnt 0 2
    /dev/mapper/vg00-home   /home                   xfs     defaults        0 0
    /dev/mapper/vg00-lateral /lateral                xfs     defaults        0 0
    /dev/mapper/vg00-tmp    /tmp                    xfs     defaults,noexec,nodev,nosuid        0 0
    /dev/mapper/vg00-usr    /usr                    xfs     defaults        0 0
    /dev/mapper/vg00-var    /var                    xfs     defaults        0 0
    /dev/mapper/vg00-swap   none                    swap    defaults        0 0
    tmpfs                   /dev/shm                tmpfs   defaults,noexec,nodev,nosuid        0 0
    l
    But after discovery on this host it find many items as writebyte/S ? Whta is the issue ? How can generate KB/S just for sda ?
  • bab
    • Aug 2020
    • 197
    Would please help me about it ?
      • 5002
      Old template with deprecated features... start by fixing template, replace any occurrence of "$1" with "{#DEVICENAME}" in discovery item prototypes.. After that (and rediscovery of items) you can actually understand, what means what..
      Butthere are also agent items like vfs.dev.read and vfs.dev.write, which should give such data without any custom userparameters..
      • bab
        • Aug 2020
        • 197
        That fixed. Would you please help me how can get total KiloByte Write/S on sda ? What is that formula ?
          • 5002
          Maybe start with docs...
          • Brambo
            • Jul 2023
            • 256
            Use a Zabbix Agent on your host?
            When not possible Linux SNMP ?
