How do I create a 'Host Prototype' in Zabbix 7.0.27?
  • fule
    • Jun 2026
    I was following an online tutorial on how to create hosts from auto-discovered storage, which requires using 'Host Prototypes' (主机原型). However, I couldn't find the 'Host Prototypes' button as described in the tutorial — I only found 'Host Templates' (主机模板). Could any expert guide me on this?
  • Brambo
    • Jul 2023
    • 256
    A template 'lives' on a host, that host receives data > which is input for the template > this input can be processed by discovery rule and that can create host prototypes
    You need to dive into LLD (low level discovery)
    • fule
      • Jun 2026
      Thank you very much.
      • fule
        • Jun 2026
        "Oh my god, I spent an entire day searching for 'Host Prototype', only to find it was right in front of me all along — it was just translated into Chinese as 'Host Template'! Please unify and standardize the naming conventions."
        • troffasky
          • Jul 2008
          • 640
          I suggest you raise this as a bug at support.zabbix.com, it is unlikely to be picked up here.
