Import 1000's of Tags for Hosts CSV
  • jimmy.mccubbins
    • Oct 2025
    • 18
    I am looking to see if someone has a CSV I can use and fill in to import into Zabbix 7.4.
    The ones I found arent doing the trick
  • troffasky
    • Jul 2008
    • 640
    Have you tried the CSV hosts importer plugin?
      • 4996
      What is your aim here at all? Importing tags to hosts from CSV? Does not look like something you can actually do ... Looks more like something you should do over API...host.update, host.massupdate methods...
      • Altrad ICT
        • May 2022
        We have a PowerShell script that uses the API to do this and hooked it up to our SharePoint inventory list so you could look at adapting it to a local CSV file. If you want a the script snippet with the web calls let me know and you'll need to setup an API users and permissions and the documentation
