the meaning of Zabbix[process,timer,,busy]
  • yaoyanxu
    • Sep 2017
    I have a question , please help me.
    In the zabbix manual, there are following explanation.
    Processes report what they are doing in shared memory and the self-monitoring process summarizes that data each second. State changes (busy/idle) are registered upon change - thus a process that becomes busy registers as such and doesn't change or update the state until it becomes idle. This ensures that even fully hung processes will be correctly registered as 100% busy.
    but, I don't understand what's the meaning.
    If zabbix[process,timer,,busy] 's value is 100%, it means CPU usage is 100%?
    please explain it .
    Thanks very much for you help.
