Multiple problem events generation and trigger expession with multiple items
  • ToomasAas
    • Apr 2012
    • 14
    I needed to create an alert message containing values of multiple items. So I used the idea from this thread: https://www.zabbix.com/forum/showthread.php?t=57337 and it works.
    The trigger expression is basically like this:
    {MyTemplate:audiences_failed.last()}>0 and {MyTemplate.audiences_total.last()}>0 and {MyTemplate:audiences_list.strlen()}>0
    I only need to send the message when "audiences_failed.last()>0", but I included the other two items so I can reference them in the message.
    The items are of type "Zabbix trapper" and they all get populated by zabbix_sender typically once a day.
    Everything fine so far, but...
    I also need the alert sent every time when the problem is detected. So I enabled the "Multiple problem events generation".
    This causes a problem (sic). As my trigger expression references 3 items, it gets evaluated 3 times and 3 messages are sent at once.
    Any suggestions for a better solution, that would allow me to:
    * send a message whenever audiences_failed.last()>0
    * include the values of audiences_total and audiences_list in the message?
    The version of Zabbix, if it matters, is 2.4.
    Thanks in advance.
