Zabbix Core Concern
  • vnoc
    • Sep 2017
    • 115
    Zabbix Core Concern
    Hi Team,
    I have recently tried to install zabbix with postgresql Database which i got struck in one of the part. Could you please help me in fixing this
    Below is the error I am getting
    The frontend does not match Zabbix database.
    Below are the steps I followed.
    1.To install and start Apache packages
    # yum install httpd httpd-devel -y
    # systemctl start httpd
    # systemctl enable httpd
    2.To install and start postgreSQL packages
    # yum install https://download.postgresql.org/pub/...5-2.noarch.rpm
    # yum install postgresql95-server postgresql95-contrib
    To Create the database cluster:
    # /usr/pgsql-9.5/bin/postgresql95-setup initdb
    # systemctl start postgresql-9.5
    # systemctl enable postgresql-9.5
    Adjust the pg_hba.conf, allowing local access without password, replacing:
    # vi /etc/postgresql/9.5/main/pg_hba.conf
    # “local” is for Unix domain socket connections only
    local all all trust
    # IPv4 local connections:
    host all all 127.0.0.1/32 trust
    # IPv6 local connections:
    host all all ::1/128 trust
    To Create the database and user zabbix:
    # psql -U postgres
    CREATE USER zabbix;
    ALTER USER “zabbix” WITH PASSWORD ‘new_password’;
    CREATE DATABASE zabbix OWNER zabbix;
    \q
    3.To install php packages
    #yum install php php-cli php-common php-devel php-pear php-gd php-mbstring php-mysql php-xml
    # vi /etc/php.ini
    date.timezone = “Asia/Kolkata”
    # /etc/init.d/httpd restart
    4.To install YUM repository for zabbix
    # yum install http://repo.zabbix.com/zabbix/3.0/rh...el7.noarch.rpm
    5.To Install Zabbix Server with MySQL
    # yum install zabbix-server-pgsql zabbix-web-pgsql zabbix-agent zabbix-get
    6.To Create Zabbix postgresSQL Database
    # cd /usr/share/doc/zabbix-server-pgsql-3.0.4/
    # zcat create.sql.gz | psql -U zabbix -d zabbix
    7.Setup Zabbix Apache Configuration
    # vi /etc/httpd/conf.d/zabbix.conf
    php_value date.timezone Asia/Kolkata
    # systemctl restart httpd
    8. Adjust the /etc/zabbix/zabbix_server.conf, adding:
    DBUser=zabbix
    DBPort=5432
    DBHost=localhost
    DBPassword = Password
    8.To Start Zabbix Server & Agent
    # systemctl restart zabbix-server
    # systemctl enable zabbix-server
    # systemctl restart zabbix-agent
    # systemctl enable zabbix-agent
    9. https://IP_Address/zabbix or https://hostname/zabbix
  • vnoc
    • Sep 2017
    • 115
    Hi Team ,
    The raised concern is fixed . You can close this thread
