Sudden dops & spikes on interface graphs
  • t4h3r0
    • Jul 2026
    • 12
    Hi everyone,
    New to the forum and relatively new to Zabbix.
    I recently finished deploying a distributed Zabbix HA cluster with proxies.
    Monitoring Cisco NCS-5500 & NCS-540X series devices using "Cisco IOS by SNMP", ZTE ZXCTN 6120H series devices with a cloned version of "Cisco IOS by SNMP" named "ZTE ROSNG by SNMP" and Huawei ATN 910 series devices with "Huawei VRP by SNMP" templates. Minimal minor changes have been made to tamplates.
    On the Cisco and ZTE devices, interface traffic graphs are exhibiting a recurring sudden drops & spikes cycles or rubber-banding pattern sharp drops followed by immediate spikes every 30 to 40 minutes. The actual physical traffic is perfectly smooth.
    This is only happening on the Cisco and less dramatically on ZTE hosts. The Huawei devices are rendering perfectly smooth, accurate graphs under the exact same network conditions. Increasing the polling interval from 1m to 2m reduced the amplitude of the spikes but did not solve the root issue.
    I would genuinely appreciate any insights, configuration tweaks or pointers you might have. Thanks in advance.
    Click image for larger version  Name:	Cisco.jpg Views:	0 Size:	268.8 KB ID:	514879
  • Rudlafik
    • Nov 2018
    • 168
    Look at the CPU and RAM consumption of the measured active network elements. The CPU values ​should not exceed 60% and RAM 80% of the consumed power in the long term. Then the active element cannot keep up with the traffic.
    • t4h3r0
      • Jul 2026
      • 12
      Originally posted by Rudlafik
      Look at the CPU and RAM consumption of the measured active network elements. The CPU values should not exceed 60% and RAM 80% of the consumed power in the long term. Then the active element cannot keep up with the traffic.
      CPU load is under 5% and RAM Uasage is around 30% to 40%
      These Cisco devices have considarably more powerful resources than the ZTE or Huawei devices
      • irontmp
        • Sep 2023
        • 99
        Originally posted by t4h3r0
        Hi everyone,
        This is only happening on the Cisco and less dramatically on ZTE hosts. The Huawei devices are rendering perfectly smooth, accurate graphs under the exact same network conditions. The issue is as unrelated to Download Subway Surfers Mod APK as it is to any other non-networking topic, which is why I've ruled out external factors. Increasing the polling interval from 1m to 2m reduced the amplitude of the spikes but did not solve the root issue.
        I'd start by checking for missed SNMP polls or interface counter issues. That kind of rubber banding often happens when a poll is delayed or a counter isn't read correctly. Since Huawei devices are fine under the same setup, I'd compare the SNMP settings and interface items between the Cisco and Huawei templates to see what's different.
        • t4h3r0
          • Jul 2026
          • 12
          I also suspect that its being caused by SNMP reply delay from device or counter misbehaving on the device..
          I'm pretty sure the spikes and drops are being caused by the zabbix tamplates > Discovery Rules > Item Prototypes
          This preprocessing step..
          cause if the value is received after even a few seconds late or early the calculation will misinterpret the value
          but could not figure out how this can be countered
          you can check the templates here https://drive.google.com/drive/folde...tI?usp=sharing
          and device SNMP config
          # Cisco SNMP Configuration #
          snmp-server user XXXXX infra v3 auth md5 encrypted 000C04150A561B105C
          snmp-server view SNMP_VIEW1 internet included
          snmp-server view SNMP_VIEW1 1.3.6.1.2.1.14 excluded
          snmp-server view SNMP_VIEW1 1.3.6.1.2.1.191 excluded
          snmp-server group infra v3 auth read SNMP_VIEW1
          # Huawei SNMP Configuration #
          snmp-agent
          snmp-agent local-engineid 800007DB0394D2BC691CDE
          snmp-agent community read cipher %^%#Tki`9,S!*("a|Y9D~-#/H_g1X*Ft*$:1#iN.!QVRVRtf7@*B6DiuuG6=zi.<'{WaK;9|3M 6F/)$hAPcV%^%# alias __CommunityAliasName_01_40655
          snmp-agent sys-info location XXXX
          snmp-agent sys-info version v3
          snmp-agent group v3 XXXX privacy read-view iso-view write-view iso-view notify-view iso-view
          snmp-agent group v3 XXXXatn privacy read-view iso-view write-view iso-view notify-view iso-view
          snmp-agent group v3 SNMP_VIEW1 authentication read-view SNMP_VIEW1 notify-view SNMP_VIEW1
          snmp-agent target-host host-name __targetHost_1_9234 trap address udp-domain 10.0.X.X params securityname XXXX@Huawei1 v3 privacy private-netmanager
          snmp-agent target-host host-name __targetHost_2_47746 trap address udp-domain 10.0.X.X params securityname XXXX@Huawei1 v3 privacy private-netmanager
          snmp-agent mib-view included iso iso
          snmp-agent mib-view included iso-view iso
          snmp-agent mib-view included SNMP_VIEW1 iso
          snmp-agent usm-user v3 XXXX
          snmp-agent usm-user v3 XXXX group SNMP_VIEW1
          snmp-agent usm-user v3 XXXX authentication-mode md5 cipher %^%#5E\E$l0>l4/_#(RMa<TCEti;7J@4CBP`}PB)"RgU%^%#
          snmp-agent usm-user v3 XXXX@Huawei1
          snmp-agent usm-user v3 XXXX@Huawei1 group XXXXatn
          snmp-agent usm-user v3 XXXX@Huawei1 authentication-mode sha2-512 cipher %^%#_zKt=/_]r.VC{mIO\C"@!&h~O'g.W:|LY08BeS0V%^%#
          snmp-agent usm-user v3 XXXX@Huawei1 privacy-mode aes128 cipher %^%#{16BBR,FpFPd4)<9v)V"QP5QDnx{>UVPc8U%8(K7%^%#
          snmp-agent trap source LoopBack0
          snmp-agent notification-log enable
          snmp-agent protocol source-status all-interface
          undo snmp-agent protocol source-status ipv6 all-interface
          undo snmp-agent proxy protocol source-status all-interface
          undo snmp-agent proxy protocol source-status ipv6 all-interface
          snmp-agent trap enable
          return
          • Rudlafik
            • Nov 2018
            • 168
            Same problem when you switch off SNMPv3 and set v1 sorry v2?
            • t4h3r0
              • Jul 2026
              • 12
              Same problem when you switch off SNMPv3 and set v1?
              did not try this one yet.. i'll try it and share findings
              • Rudlafik
                Rudlafik commented
                Sorry, no v1 but v2
            • t4h3r0
              • Jul 2026
              • 12
              observed for the last 12 hours with SNMP V2C.. same same
              • Rudlafik
                • Nov 2018
                • 168
                look on: SNMP data spikes
                Spikes in SNMP data have been observed that may be related to certain physical factors like voltage spikes in the mains. See ZBX-14318 more details.
                If combined requests cause partial or malformed responses that result in incorrect per-second (delta) calculations (for example, apparent spikes in interface counters), disable Use combined requests for the affected interface to force separate per-item queries; this often prevents false spikes. Alternatively, consider using asynchronous get[] or walk[] items, which are executed asynchronously and are not subject to the per-interface Use combined requests batching — they can be used instead of legacy synchronous OID checks to avoid combined-request related issues. Look for server/proxy log entries similar to the one shown in the Overview section to help identify affected devices.
                • Rudlafik
                  • Nov 2018
                  • 168
                  Try ZBX resulution, (https://www.zabbix.com/documentation...=SNMP#overview)
                  All cisco switch. In production time in night time. In izolated lan with oneor two ports, in direct to power or power by UPS or PDU, In factory settings.
                  • t4h3r0
                    • Jul 2026
                    • 12
                    see this https://www.zabbix.com/forum/zabbix-...traffic-graphs
                    my issue is exactly this.. i also have other monitoring, whichshowing accurate data
                    i dont think this is being caused by any physical factor
                    • Rudlafik
                      • Nov 2018
                      • 168
                      OK other app present data coretly. Same issue when monitoring cisco from central server and bypass ZABBIX proxy? Time synchronization is corect on ZBX proxy vs cisco swi and ZBX server? Das Is zbx proxy VM on an virtualization platform?
                      Same data oscilation when you create item snmp wit hpecific OID without any postprocesing setings (1 - 4)? Would you try creating standard SNMP entry and adding one by one preprocessing to data process (from the beginning of your ZBX env presentation)? Test between adding individual postprocessing steps.
