Specific parameters in email notification
  • boleh
    • Sep 2017
    I am currently attempting to create an email notification using "Action" feature under "Monitoring" menu. I do receive the output (at the bottom of this message), by inserting {ITEM.VALUE1}, which is the SNMP trap, in the email configuration.
    However, I would like to simplify the email format notification, basically to report a few critical parameters in the email rather than all detailed information in {ITEM.VALUE1}.
    Are there any expressions or variables such as {Trigger.name}, {Item.Name} and etc, or any other methods that I can possibly use? For instance, I plan to have ONLY "Network-101" in my email subject and body content, instead of: -
    (1) SNMP-MIB::alarmB.0 type=4 value=STRING: "Network-101"
    OR
    (2) all the information under "VARBINDS".
    Thank you.
    VARBINDS:
    DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (160993210) 31 days, 8:47:23.21
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMP-MIB::nmsAlarm
    SNMP-MIB::alarmA.0 type=2 value=INTEGER: 11
    SNMP-MIB::alarmC.0 type=2 value=INTEGER: 2
    SNMP-MIB::alarmD.0 type=4 value=""
    SNMP-MIB::alarmE.0 type=4 value=STRING: "101"
    SNMP-MIB::alarmF.0 type=2 value=INTEGER: 3
  • boleh
    • Sep 2017
    Greatly appreciate if someone can share their experience and knowledge with me.
