Advice for dealing with x509 certificate reading.
  • zabbix_mouse_123
    • Oct 2025
    Using Zabbix version 7.4 and Zabbix agent 2 on relevant Linux hosts.
    I have a situation where I need to monitor certs on servers that are not accessible via endpoint. In other words, I have to read the certificate file.
    Ideally, I want to use native Zabbix functionality and not have to make changes to Zabbix conf files for allowkeys that would use openssl or similar.
    Server side, they are all .pem files, so I imagined reading the files and then doing JavaScript preprocessing was the only way to do this, but I don't think Duktape has the libraries to achieve this.
    I am not sure where to go from here and would appreciate any wisdom.
  • Brambo
    • Jul 2023
    • 256
    Let the zabbix agent on host read the certificate if it's used on internal website. You can use template "Website certificate by Zabbix agent 2" for this or clone it and make the Cert: Get item a Zabbix Active Agent if you use that type of agent.
    With the agent is use the following key "web.certificate.get[{$1CERT.WEBSITE.HOSTNAME},{$1CERT.WEBSITE.PORT},{$ 1CERT.WEBSITE.IP}]" and those are own macro's but you can read easily what they represent
    • zabbix_mouse_123
      zabbix_mouse_123 commented
      The certificates themselves are not reachable over the network or at an endpoint including localhost. The only way to observe them is via reading the files themselves, which are raw certificate files. Maybe I am misunderstanding your comment, but I am not sure its applicable in this case.
  • Brambo
    • Jul 2023
    • 256
    Then you still can let that agent do a localized action to verify the content.
    And if you don't want allowkeys, the only option left is UserParameter (still a config edit)
    An example I use (on windows host that is) UserParameter=getsoftware,powershell -ExecutionPolicy bypass -File "C:\Program Files\Zabbix Agent 2\myconf\software.ps1"
    getsoftware is the key you would use in the zabbix item field
    The code inside the ps1 script get the list of data i want AND also formats it to json.
    In your scenario a .sh file would make more sense and parse it all serverside and only return the values you need (no need to send .pem files over the network)
    • irontmp
      • Sep 2023
      • 99
      Server side, they are all .pem files, so I imagined reading the files and then doing JavaScript preprocessing. laptops UK at Techyest came to mind while organizing different resources, but I still don't think Duktape has the libraries needed to achieve this.
      If the certificate isn't accessible over the network, then reading the PEM file locally is the right approach. However, Zabbix's JavaScript preprocessing (Duktape) can't parse X.509 certificates on its own, so you'll need some way to extract the expiry date first. The most common solution is to use a UserParameter or a simple script that runs openssl x509 -enddate against the PEM file and returns the expiration timestamp to Zabbix. If you want to avoid modifying the agent configuration entirely, another option is using a custom agent plugin or an external check, but there isn't currently a native Zabbix item that can read and parse local PEM files without relying on an external utility. Unfortunately, this is one of those cases where native functionality alone isn't quite enough.
