Installed zabbix v3.4, GUI is showing zabbix server is not running
  • Akansha123
    • Jun 2016
    • 54
    I have installed zabbix v3.4 its GUI is showing zabbix server is not running though I have checked the services using netstat it is running on default port (10051). Even I am able to fetch items successfully.
    can anybody please explain why it is happening?
  • allexpetrov
    • May 2017
    • 361
    Hi Akansha123,
    You have installed the zabbix from the packages or you've installed zabbix from the sources? Check the permissions and under which user the zabbix server is running?
    Regards,
    Alex!
    • deepak72840
      • Sep 2017
      It seems you are missing the zabbix web and need to copy config file from apache(if you are using apche web server).
