Any macro with "NOTE: Escalation cancelled ..." in?
  • troffasky
    • Jul 2008
    • 640
    Have a custom webhook sending a JSON event for trigger fire/clear. I have noticed that for an "escalation cancelled" event, this bit of the message does not appear in our payload and I cannot work out what macro it would be in. So it just looks like the original problem webhook being sent an hour later.
    I have tried {ALERT.MESSAGE} but that is just the original message without the 'NOTE: Escalation canceled: trigger "<whatever>" disabled.' part.
    Is there any macro I could use to infer that the trigger was disabled?
    Zabbix 7.0
    • 5002
    its in the code...
    Real-time monitoring of IT components and services, such as networks, servers, VMs, applications and the cloud. - zabbix/zabbix
    • troffasky
      • Jul 2008
      • 640
      Well, it looks like it always uses the same medium as before.
      I guess the problem is my webhook media type script:
      var params = JSON.parse(value);
      var req = new HttpRequest();
      req.addHeader('Content-Type: application/json');
      var payload = JSON.stringify({
          event_id: params.event_id,
          host_name: params.host_name,
          host_ip: params.host_ip,
          host_group: params.host_group,
          trigger_name: params.trigger_name,
          note: params.note,
          severity: params.severity,
          //status: params.event_status,
          trigger_state: params.trigger_state,
          trigger_status: params.trigger_status,
          timestamp: params.timestamp,
          //fullmessage: params.alert_message,
          tags: params.eventtags,
          event_value: params.event_value,
          event_ack: params.event_ack,
          event_ack_time: params.event_update_time,
          event_recovery_value: params.event_recovery_value,
          event_recovery_time: params.event_recovery_time
      var resp = req.post(params.url, payload);
      if (req.getStatus() !== 200) {
          throw 'Request failed with status ' + req.getStatus() + ': ' + resp;
      return 'OK: ' + resp; zz0.7uy9y8kjb1ozz
      trigger_state and trigger_status are {TRIGGER.STATE} and {TRIGGER.STATUS}, respectively. {TRIGGER.STATE} never resolves to anything.
      An Escalation Cancelled message results in this payload:
        "event_id": "37689781",
        "host_name": "Test Host 5",
        "host_ip": "17.0.0.5",
        "host_group": "Miscellaneous Customers",
        "trigger_name": "\"ExampleSvc\" (Example Service) is not running",
        "note": "{EVENT.UPDATE.MESSAGE}",
        "severity": "Disaster",
        "trigger_state": "{TRIGGER.STATE}",
        "trigger_status": "PROBLEM",
        "timestamp": "17:09:00",
        "tags": "Application:Status, windows-service",
        "event_value": "1",
        "event_ack": "Yes",
        "event_ack_time": "{EVENT.UPDATE.TIME}",
        "event_recovery_value": "{EVENT.RECOVERY.VALUE}",
        "event_recovery_time": "{EVENT.RECOVERY.TIME}"
      [not sure why ack time is blank, the event was acked!]
      • troffasky
        • Jul 2008
        • 640
        "fullmessage" was {ALERT.MESSAGE} - this was the entire original message and didn't include the 'escalation cancelled' bit.
        • troffasky
          • Jul 2008
          • 640
          I tried {ESC.HISTORY}, this contains everything except the cancellation of the escalation; the documentation says "The log of previously sent notifications", so that is literally true as it would never include the current step.
          • irontmp
            • Sep 2023
            • 99
            Originally posted by troffasky
            Have a custom webhook sending a JSON event for trigger fire/clear. I have noticed that for an "escalation cancelled" event, this bit of the message does not appear in our payload, and while checking letras bonitas, I cannot work out what macro it would be in. So it just looks like the original problem webhook being sent an hour later.
            I have tried {ALERT.MESSAGE} but that is just the original message without the 'NOTE: Escalation canceled: trigger " " disabled.' part.
            Zabbix 7.0
            There isn’t a macro for that specific “Escalation canceled” text in Zabbix 7.0. {ALERT.MESSAGE} is only the original alert message, so it won’t include the cancellation note. For a webhook, you’ll need to infer it from the event/action context, such as the trigger/event status, rather than from {ALERT.MESSAGE} itself.
