Synology Template Overhaul: SNMP issue tracking disks as LLD hosts
  • killom
    • May 2022
    I am currently trying to track all the disks of several Synology NAS systems in Zabbix.
    The goal is to keep the NAS as the main host, while creating the individual disks as separate hosts through low-level discovery. This would allow us to track SMART values and attach disk-specific triggers and inventory information to each drive, and keep each information
    The disk information is spread across several SNMP tables. Depending on the Synology model, I can receive:
    Serial numbers
    Model names
    /dev/sdX
    or
    sataX
    device names
    SMART attribute names and raw values
    The table positions cannot be used for matching, so the entries have to be correlated by their identity. For example:
    /dev/sda = sda = Drive 1
    This part is working reasonably well.
    The problem is that the parent NAS host and the discovered disk hosts all use the same SNMPv3 interface and target IP. This unpleasantly leads to errors:
    SNMP engineId is not unique
    It appears that simply adjusting the check intervals is not a reliable solution. The conflict is related to the same SNMP source being monitored through multiple Zabbix hosts.
    I mean, it is working ... somehow. The engineID will always collide somewhere else, so all metrics will finally arrive at some point. But I wouldn't call it "reliable"
    Has anyone implemented a similar parent/child design, or can recommend the cleanest approach for this in Zabbix? I dont want to loose the individual tracking for the discs, because this way it is easier to view and monitor such assets.
  • rozols
    • Aug 2026
    • 12
    Maybe its worth checking out Synology DiskStation template - github.com/initMAX/Zabbix-Templates, under Synology_NAS, it uses a single master SNMP walk item per NAS, dependent items and LLD for the individual disks, rather than separate hosts each independently polling the same SNMP target. Since there is only one poller touching the IP per cycle, this avoids the engineID collision.
