[Zabbix 3.4 - Ubuntu] SNMP traps not logging
  • kasik
    • Aug 2017
    • 30
    Hi guys,
    i have a problem with SNMP traps to get them into tmp log and into zabbix.
    I set it up as in documentation using snmptt without perl. and even when i have set log file to be /tmp/zabbix_traps.tmp in zabbix_server conf and in snmptt too i just don't get any but when i send test trap from monitored server with tcpdump -i xxx port 162 i can see that i recieve it... Any idea where is the problem? i even checked if services is running and modified chmod on log file to 777... please help
  • kasik
    • Aug 2017
    • 30
    update
    any ideas ?
    • kasik
      • Aug 2017
      • 30
      Resolved
      So i found solution with this command:
      snmptrapd -A -Lf /tmp/snmptrapd.log
      and it showed me this:
      NET-SNMP version 5.7.3 AgentX subagent connected
      couldn't open udp:162 -- errno 98 ("Address already in use")
      so i reconfigures snmpd.conf where i changed used ports and restarted service
      then again used first command and in log i saw its connected so i send traps and now they are in tmp log :-)
      • Gege
        • Sep 2017
        same symptom, same methos, other reason
        Thank you, Kasik for this post. I had the same problem of not receiving any trap.
        I used the same command
        and found in snmptrapd.log that snmptrapd would not receive any trap as long as there would not be an access method defined in snmptrapd.conf. So I opted for the fast method and decided to removed the access method by inserting:
        disableAuthorization yes
        in snmptrapd.conf
        I now receive everything,
        following zabbix documentation I attempted to test the configuration using zabbix_sender, but it was not part of the initial installation. It was not either installed by zabbix-agent installation. the right way to do it is
        apt-get install zabbix-sender (with a - not a _)
