Web Scenarios & Notifications
  • DepstR
    • Aug 2026
    Hi all,
    I'd like to monitor a lot of our private websites on the local network. I've read that this can be achieved via Web Scenarios. For context, I'm used to traditional web monitoring solutions (status pages etc.).
    We have about 10 servers on the network, each hosting a couple of sites on different FQDNs. So for each site I want to monitor, I've created a web scenario.
    But that alone does not give me alerts/notifications. As far as I've dug and looked... it isn't native? By my understanding I'd need a trigger to generate a problem, and based on that I can get a notification/alert.
    I figured I'd create a generic template that would give me a generic trigger like "Web: example.com is unhealthy / not OK" but for that I need the scenario name. As far as I've read, I can't achieve some type of Discovery to create these triggers automatically either.
    I'm new to Zabbix and a bit lost in the UI. The fact that this is a long-term production setup with a lot of old/legacy templates and dashboards doesn't help either.
    Zabbix version. 7.0.28
    Am I missing something?
    Any help or point in the right directions would be very welcomed.
    Thanks.
    • 5002
    Web scenario only creates items for it, https://www.zabbix.com/documentation...nitoring/items
    You have to create triggers using those items. Discovery does not allow you to create web scenarios..
    A general template might be possible, if you use macros in it, what you can later define on host level.
    • kyus
      • Feb 2024
      • 210
      We currently have a generic template with certain macros so we can use it for every website we want to monitor.
      We have: {$RETURN.CODE}
      {$SEARCH.TEXT}
      {$URL}
      Those 3 are for the sake of creating items. But we also have 2 macros for the trigger: {$CLIENT} and {$SITE}
      Trigger name is: {$CLIENT} - Website - {$SITE} - unavailable
      Trigger expression:
      sum(/Web monitoring/web.test.fail[Websites],#3)>=3
      Recovery:
      max(/Web monitoring/web.test.fail[Websites],#3)=0
      Websites inbetween the brackets is the name of my web scenario.
      It works great, but you need to create one host for each website.
      • DepstR
        DepstR commented
        So if i have 9 websites on one physical server (host in zabbix) i need to create 9 hosts?
    • kyus
      • Feb 2024
      • 210
      With this specific setup that I shared yes, you'll have to create 9 hosts, one for each website.
      And those hosts don't need an interface, unless you want to monitor certificates with the zabbix agent2 template.
      • irontmp
        • Sep 2023
        • 99
        Originally posted by DepstR
        Hi all,
        I figured I'd create a generic template that would give me a generic trigger like “Web: example.com is unhealthy / not OK,” but for that I need the scenario name. I’ve been dealing with a few unrelated projects as well, including deck repair Knoxville, so I’m trying to keep the Zabbix configuration as automated and maintainable as possible. As far as I’ve read, I can’t use Discovery to create these triggers automatically either.
        Thanks.
        Yes, you’re understanding it correctly. Web scenarios collect the monitoring data, but you need a trigger to turn a failed scenario into a problem and then an action to send the notification. For a large number of sites, manually creating triggers can become cumbersome. Zabbix 7.0 doesn’t provide low-level discovery that automatically creates triggers for every web scenario. You can either build a template with the required trigger logic and apply it consistently, or automate the creation of scenarios, items, and triggers through the Zabbix API. For your setup, I’d recommend using the API if you expect the number of monitored sites to keep growing. It will save a lot of manual work and keep the configuration consistent.
