Differences in interfaces found
  • RichardNL
    • Apr 2023
    Crucial information:
    Production environment:
    Host OS: ubuntu-26.04-live-server-amd64
    Zabbix version: 7.4.13
    Database: MySQL
    Webserver: Nginx
    Template used: Windows by SNMP
    Template Vendor and version: Zabbix, 7.4-4
    Test environment:
    Host OS: Zabbix appliance (Alma Linux 8)
    Database: MySQL
    Webserver: Nginx
    ​Template Vendor and version: Zabbix, 7.2-2
    Small introduction: In the past I had an small Zabbix setup. Overwhelmed by all the options, I choose to switch to NagiosCSP. It worked for us, easier to setup and free for 50 devices. Unfortunately, because of changes in their policy, the CSP license is revoked. With my small experience with Zabbix I choose to come back. I've made myself an test environment based on the Zabbix appliance. Added an host, with help of AI created a specific service readout with a trigger. It was quite doable for me, and it no longer felt like a raging river. By testing things at my leisure I was getting somewhere. But, for the appliance I read that it is not the best option for production purposes. So, pulling the Ubuntu ISO to our cluster, attached it to the Nagios VM and formatted the whole server. LET'S START! I felt confident as my test-enviroment did what i wanted.
    Server installed etcetc. Added a host, just like my test environment. Same host, same template, same SNMP settings etc. Wait, WHAT? Where I had 135 items and 15 triggers for the host in the test environment, I now have 203 items and 90 triggers for the same host in my 'production'-environment! In my search for the difference, I found out there where more network interfaces added. In test: 1 interface, production around 7 I guess? As I'm using the same template etc, I tried to investigate where the difference is made.
    With help of AI (and running around a lot in the same circles, TNX AI!) it seems that the appliance (test environment) receives the same data for the network interfaces discovery. But, in production it seems that the interfaces that would normally be filtered out by the macro's (which apparently works in test) are now still added. While comparing data it looks like the test environment for example receives the netwerk interface names as QoS, teredo etc. In production, it looks like the interface names are moved to the interface description, where a different macro is applied and therefore the interfaces aren't filtered out. But, this is a guess...
    Some information from the database to show the found interfaces:
    Production:
    mysql> SELECT DISTINCT
        ->        SUBSTRING_INDEX(
        ->          SUBSTRING_INDEX(i.name,'(',-1),
        ->          ')',1
        ->        ) AS interface_name
        -> FROM items i
        -> JOIN hosts h ON h.hostid = i.hostid
        -> WHERE h.host = 'SVR-MAC-APP03'
        ->   AND i.flags = 4
        ->   AND i.key_ LIKE 'net.if.in[%'
        -> ORDER BY interface_name;
    | interface_name                                                   |
    | Ethernet0                                                        |
    | Ethernet0-QoS Packet Scheduler-0000                              |
    | Ethernet0-WFP 802.3 MAC Layer LightWeight Filter-0000            |
    | Ethernet0-WFP Native MAC Layer LightWeight Filter-0000           |
    | Local Area Connection* 1                                         |
    | Local Area Connection* 2                                         |
    | Local Area Connection* 3                                         |
    | Local Area Connection* 4                                         |
    | Local Area Connection* 5                                         |
    | Local Area Connection* 6                                         |
    | Local Area Connection* 7                                         |
    | Local Area Connection* 7-QoS Packet Scheduler-0000               |
    | Local Area Connection* 7-WFP Native MAC Layer LightWeight Filter |
    | Local Area Connection* 8                                         |
    | Local Area Connection* 8-QoS Packet Scheduler-0000               |
    | Local Area Connection* 8-WFP Native MAC Layer LightWeight Filter |
    | Local Area Connection* 9                                         |
    | Local Area Connection* 9-QoS Packet Scheduler-0000               |
    | Local Area Connection* 9-WFP Native MAC Layer LightWeight Filter |
    | Loopback Pseudo-Interface 1                                      |
    20 rows in set (0.00 sec)
    Test:
        ->        SUBSTRING_INDEX(
        ->          ')',1
        -> FROM items i
        ->   AND i.flags = 4
    | interface_name |
    | Ethernet0      |
    1 row in set (0.00 sec)
    When running an SNMP walk to the same host, there are also differences to see: On the production server the response is in HEX, on the testserver i receive a response in text. A small part of the output:
    Production:
    snmpwalk -v2c -c thisissecret:) hostip 1.3.6.1.2.1.2.2.1.2
    iso.3.6.1.2.1.2.2.1.2.1 = Hex-STRING: 53 6F 66 74 77 61 72 65 20 4C 6F 6F 70 62 61 63
    6B 20 49 6E 74 65 72 66 61 63 65 20 31 00
    iso.3.6.1.2.1.2.2.1.2.2 = Hex-STRING: 57 41 4E 20 4D 69 6E 69 70 6F 72 74 20 28 4E 65
    74 77 6F 72 6B 20 4D 6F 6E 69 74 6F 72 29 00
    Test:
    IF-MIB::ifDescr.1 = STRING: Software Loopback Interface 1.
    IF-MIB::ifDescr.2 = STRING: WAN Miniport (Network Monitor).
    Can someone give me a helping hand in achieving the same results in both enviroments?
  • troffasky
    • Jul 2008
    • 639
    I assume there is some difference in interfaces for discovery macros on SNMP and Windows Agent templates.
    • RichardNL
      • Apr 2023
      Tnx for your reply. In both cases (test and production) I used the same templates, Windows by SNMP. I checked the result in the discovery rule, and that looks almost the same, as in: On both environments the same QoS and WFP are found. But, only in the production all interfaces are added, as if it is being ignored by the filters.
      • troffasky
        • Jul 2008
        • 639
        Sorry, I didn't notice that it was the same template and different Zabbix versions.
        Still, I advise you compare {$NET.IF.*MATCHES} macros across the different templates. As a macro can be overridden at host level as well, check it there too [although you cannot "accidentally" define a macro on a host so you would probably remember changing this].
