Building Item and Trigger
  • vlam
    • Jun 2009
    • 166
    Hi All
    I need some help with creating an item for the following and a trigger for it if anyone can help
    zabbix_sender -z {Zabbix_Server_IP} -p 10051 -s " CloudOpera Server " -k trap -o "{"severity":"high","meDn":494918576192174203,"add itionalInformation":"Peer IP:Peer_IP","probableCause":"","meName":"OC108OC", "alarmId":"OC_00009007","alarmName":”Host NTP connection failed ","csn":258143} "
    Any help in getting this right will be greatly appreciated
    4 Zabbix Frontend Servers (Load balanced)
    2 Zabbix App Servers (HA)
    2 Zabbix Database Servers (HA)
    18 Zabbix Proxy Servers (HA)
    3897 Deployed Zabbix Agents
    6161 Values per second
    X-Layer Integration
    Jaspersoft report Servers (HA)
  • allexpetrov
    • May 2017
    • 361
    Could you please provide more details on what you actually want to perform, otherwise I can't understand:
    1. When trigger should fire ? On which value or which change or what?
    2. What are you trying to get? I mean which VALUE you are receiving from that -o command?
    3. You don't need to define the port if it goes with the standard one
    Also, zabbix-sender is a local command line utility. Why you are trying to use macro as a server name ? Instead of that try to define $VARIABLE for it and pass it to the command.
    P.S. - Type = Zabbix trapper
    Please go through the manual - https://www.zabbix.com/documentation...cepts/sender?s[]=zabbix&s[]=sender
    Regards,
    Alex!
    • vlam
      • Jun 2009
      • 166
      Hi
      I need to monitor components of a Huawei Cloud environment that is being setup, as this has its own monitoring components it logs everything already but they cannot integrate into our call logging systems so the plan is to monitor the error output logs from there monitoring and then we can on the type of error being picked up log calls for the support teams.
      X-Layer Integration
      • allexpetrov
        • May 2017
        • 361
        Can your devices put the log into syslog on some 3rd server ? You can parse with log[] item that syslog contents and put them into Zabbix.
        Regards,
        Alex!
