hosts not showing.
  • CarlosTech
    • Aug 2017
    • 20
    hosts not showing.
    I have been trying to make my actions a little more targeted, i.e. if a machine comes from a specific vlan add it to the "desktop" hostgroup etc.
    unfortunately in doing this, it's caused my discovery to break... i.e. the machine is discovered and added to the hostgroup... but i cannot see it in "hosts" so i get no reporting on the triggers or anything like that.
    i'm a bit lost now. anyone point me in the right direction?
    i got a feeling i've un-linked it from a template which was crucial but i don't know which one.
  • LenR
    • Sep 2009
    • 1010
    Are you logged in as a super admin?
    Can you search for the host name?
    What version of Zabbix?
    Something sounds familiar, I think I managed to get a host with no groups once and it acted like this.
    • CarlosTech
      • Aug 2017
      • 20
      only have the one account (i'm still testing zabbix)
      i can see the host when i look at the "discovery" tab in monitoring, but it's not hyperlinked like it was previously.
      sorry running version 3.4
      it's part of my desktop group i created and also set the action to remove it out of the discovered hosts group.. but that was also set before.
      • CarlosTech
        • Aug 2017
        • 20
        hold on, i just realised i'm confusing the discovery rule with hostgroups...
        i can't see the hosts in the gorups... and my action don't seem to be putting the hosts in their groups... that might be the issue here!
        • LenR
          • Sep 2009
          • 1010
          That sounds like it's 'only' discovering the host, your discovery action isn't working. Does your action send a message? Are you getting the message?
          • CarlosTech
            • Aug 2017
            • 20
            no it doesn't send a message... i can set that and see if the action even works?
            • CarlosTech
              • Aug 2017
              • 20
              i don't think my actions are even triggering.. very odd.
              • CarlosTech
                • Aug 2017
                • 20
                so i've recreated my discovery rule and discovery actions again. this is how they read:
                discovery rule:
                ip range : 10.1.0.0-254
                Checks: Zabbix agent "system.uname"
                uniquness: Zabbix agent"system.uname"
                enabled
                auto discorver rule:
                Conditions-
                Discovery rule = Desktop Subnet
                Received value like Windows
                Discovery status = Up
                Service type = Zabbix agent
                operations-
                Send message to users: Admin (Zabbix Administrator) via Email
                Add to host groups: CF Desktop Machines
                Remove from host groups: Discovered hosts
                Link to templates: Template OS Windows
                i will see if this works and report back.
                • LenR
                  • Sep 2009
                  • 1010
                  I use auto registration, not discovery. I don't know if the discovery action fires just at the first discovery, but you might delete one of your vlan discovery rules then add it pack.
                  • CarlosTech
                    • Aug 2017
                    • 20
                    think i sussed it Len.
                    i've set the following up. an action that creates a host. then another action that adds the host in to a group.
                    Auto discovery. Windows Host.
                    Add host
                    Set host inventory mode: Automatic
                    Enabled
                    Group. Windows Desktop.
                    Enabled
