I'm trying to build an item for a Zabbix 3.4 template to perform DNS checks. Based on the documentation I should be using `net.dns[<ip>,name,<type>,<timeout>,<count>,<protocol>]`. If I specify an external DNS resolver such as Google or OpenDNS I get the expected return of 1.
However, when I remove the resolver IP and allow it to use default I get no data returned. The same happens when I manually specify the IP address in /etc/resolv.conf.
Thank you in advance for any help!
