Trigger on usrpara
  • gerwinnl
    • Sep 2026
    Trigger on usrpara
    We use active agent usrpara to monitor on windows. When everything works it reports 0 / 1.
    But when the script timeout or for example the script is wrong and the info message says: "value of type "string....." We get no data in the last value check.
    Is it possible to create a trigger on the item when last value is empty or when the info message has a error?
    • 5002
    You could use preprocessing there in item conf...
