API returning macro names instead of macro values
  • icol
    • Aug 2014
    • 31
    I am getting alarms from zabbix an export it to another tool in almost real time
    I do this by polling the zabbix api every minute
    this is the cmd i use in the api
    payload = {
    "jsonrpc" : "2.0",
    "method" : "trigger.get",
    "params": {
    "output": "extend",
    "monitored": "1",
    "selectHosts": "extend",
    "lastChangeSince": before,
    "sortfield":"lastchange"
    "auth" : self.auth,
    "id" : 2,
    headers = {
    'content-type': 'application/json',
    This is the example of the description with an error:
    "Disk I/O is overloaded on {HOST.NAME}"
    Instead of the {host.name} it should have been the name of the host
    is this a bug?
    Somthing wrong in the way i send my cmd?
    Thanks in advance for any help
  • Semiadmin
    • Oct 2014
    • 1626
    Hi, icol.
    Try to add param "expandDescription" : "1"
    • icol
      • Aug 2014
      • 31
      Hi Semiadmin!
      it worked
