TELEMETRY_QUERY filter — Are macros supported in filter condition values?
  • Tejasree
    • Jan 2025
    Hi Team,
    I'm on Zabbix 8.0.0rc2 collecting OTEL gauge metrics via TELEMETRY_QUERY items. My ClickHouse has data from multiple devices, and I need each host to filter for its own device at the query level., where my hosts would be created dynamically from discovery.
    What I tried:
    Adding ResourceAttributes.device.name as a filter condition with a macro:
    filter: conditions:
    - column: MetricName
    value: my.metric.name
    - column: ResourceAttributes
    attribute_key: device.name
    value: '{$MY.DEVICE}'
    The macro {$MY.DEVICE} is correctly set on the host (value = mydevice01.example.com).
    I also tried {HOST.HOST}.
    Both return no data.
    It appears the filter condition value field treats macros as literal strings — it's querying ClickHouse for ResourceAttributes['device.name'] = '{$MY.DEVICE}' instead of resolving it to mydevice01.example.com. So the query matches nothing.
    What works:
    If I remove the ResourceAttributes filter and instead filter in a JavaScript preprocessing step, the same macro resolves fine and returns data:
    var c = JSON.parse(value).columns;
    if (c['ResourceAttributes.device.name'] === '{$MY.DEVICE}')
    { return c.value;}
    return '';
    So the macro resolves in preprocessing but not in the TELEMETRY_QUERY filter.
    Why this matters:
    Without query-level filtering, the TELEMETRY_QUERY returns data for all devices and preprocessing has to discard non-matching rows. This works but is inefficient — especially with many devices.
    Questions:
    1.Are macros supported in TELEMETRY_QUERY filter condition values, or are they treated as literal strings by design?
    2.If not currently supported, is this planned for a future release?
    3.Is there a recommended way to filter by a per-host dynamic value at the query level?
    Thanks​
