Critical PHP CVE released and patched today. When will Zabbix docker catch up?
  • ZabbixSeeker
    • Mar 2026
    • 34
    A vulnerability for full remote code execution on PHP applications was released today. It was also hotpatched today.
    This is super critical.
    Do we have any information on when Zabbix will patch zabbix in its docker container?
  • ZabbixSeeker
    • Mar 2026
    • 34
    Here is a workaround for you guys meanwhile. Assuming ubuntu. Assuming php version 8.5 in your container. You can check it with php -v.
    1. exec bash in the container as root.
    2. apt update
    3. apt install --only-upgrade -y 'php8.5-*'
    4. check: dpkg-query -W php8.5-fpm .... should be at least this patch: 8.5.4-0ubuntu1.5
    5. restart the web container
    You are welcome.
    • dsdsdk
      • May 2024
      Thank you for workaround.
      I see some php update from yesterday, but not for Alpine image, anyone know why? https://github.com/zabbix/zabbix-doc....4/Dockerfiles
      • ZabbixSeeker
        ZabbixSeeker commented
        The images are still outdated. They need to rebuild.
        The change you're referring to at this point has in itself no meaningful security implications either.
    • ZabbixSeeker
      • Mar 2026
      • 34
      There will probably be an implicit unintended patch when the image for the next zabbix patch version 7.0.33(?) is released, if the one who builds it doesn't build it with docker cache on. My expectations regarding any other actions, at least in reasonable time, is low.
      • aqualkenbush
        • Oct 2026
        I use the Alpine Linux 3.2.1 container for Zabbix, here are my notes for fixing this, similar to what is shown above for apt.
        ## enter the container as root
        docker container exec -u 0 -it zabbix-web-nginx-pgsql /bin/bash
        ## see your current version, I was at 8.3.19
        php-fpm83 --version
        ## update repo cache
        apk update
        ## list package
        apk search php-fpm83
        ## install
        apk upgrade php83-fpm
        YMMV, can't tell if this breaks anything, but I haven't seen any issues yet.
        • aqualkenbush
          aqualkenbush commented
          Left out above, you probably also want to upgrade the php83-common package.
          Also in the container, for that other PHP vulnerability, CVE-2026-115560:
          cat > /etc/php.d/99-security.ini <<'EOF'
          session.upload_progress.enabled=0
          EOF
          Then restart the container.
      • GermanFP
        • Oct 2026
        In my case, I use Docker Compose with Nginx on an Alpine image.
        I followed these steps:
        - I logged into the container as root.
        - I ran the update command for PHP only: `apk upgrade $(apk info | grep ‘^php84’)`
        - Then I restarted the container.
        • PeterStegemannSIX
          • Feb 2023
          Their statement does not sound like they plan to release fixed images anytime soon, so to say.
          • PeterStegemannSIX
            • Feb 2023
            Actually, new images have been available on the next day, no idea why they did not point that out in their press release.
            • ZabbixSeeker
              It was not. I checked then and multiple days afterwards. There was (just like I suspected) an involuntary accidental patch due a newer Ubuntu base image used in a later release with unrelated changes.
