Removing / Commenting out Favorites Graphs/Screen/Maps on Zabbix 3.0.10
  • zabbixfk
    • Jun 2013
    • 256
    Wanted to know how to remove Favorites Graphs/Screen/Maps on Zabbix 3.0.10 dashboard.
    I use to comment out Favorite screens/grpahs/maps on 2.2.12 on dashboard.php, but i don't see that file in 3.0.10.
    Can someout point out how to do it in 3.0.10
  • allexpetrov
    • May 2017
    • 361
    It's not recommended to modify the php files. You can run into different issues in the future.
    I would like to suggest to upgrade to 3.4.2 because since 3.4.0 Zabbix has customizing dashboard option.
    Zabbix 3.4 whats new: https://www.zabbix.com/documentation...on/whatsnew340
    Regards,
    Aleksejs!
    • zabbixfk
      • Jun 2013
      • 256
      Thanks for the reply.
      Just curios, how did this work in 2.2.12 ( been doing it since 2.0.6).
      Also i just upgraded ( testing ) from 2.2.12 to 3.0.10, if you are telling me to go for 3.4 not sure what will break - my production system has complete monitoring dependency of 5K devices
