zabbix installation on ubuntu 6.06 LTS
  • krischeu
    • Jan 2007
    Hello NG,
    i am new to zabbix and i want to test it in our environment. So i decided to install Ubuntu 6.06 LTS on VMware-server as LAMP-installation. Installing Ubuntu is so far not really a problem.
    I installed the following packages by using apt-get with standard-sources of /etc/apt/sources.list (changes are only done by deleting the "#"!!).
    I am running kernel 2.6.15.27 with 256 MB RAM.
    After downloading the sources zabbix-1.1.4.tar.gz i run into problems with missing packages.
    So i installed with apt-get install:
    openssh-server, mysql-client, linux-image-server, gcc, make, openssl, libssl-devel, libmysql++-dev, libapache2-mod-php, php4-cgi
    By starting ./configure -with-mysql -with-net-snmp i ran into problems, that it cannot find some snmp-develop-libraries. I decided to compile it by myself and download it from sourceforge net-snmp 5.4.
    After this was done the compilation of ./configure -with-mysql -with-net-snmp looks good and the suggestion from the program to do a "make" looks fine to me.
    I run "make" "make install" but in the ./bin directory are only 2 windowsexecutable. I want to run the zabbix-server as server and client AND other clients should send information to zabbix-server.
    What have i done wrong? I know i could get installtion files from apt-get install zabbix ..., but i want to install it from scratch.
    Every hint is usefull for me.......
  • krischeu
    • Jan 2007
    Zabbix 1.1.4
    root@zabbix:/usr/local/zabbix/zabbix-1.1.4# ./configure --enable-server --enable-agent -with-mysql -with-net-snmp
    make
    make install
    What follows up now? I did this as root and i want to change to user "zabbix".
    Any hints?
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Ubuntu 6.06 LTS is a perfect platform for ZABBIX. The distribution contains all necessary packages to build and run ZABBIX. No need to install any third-party software from source.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • krischeu
        • Jan 2007
        is there a desciption about installing zabbix with apt-get and the needed packages?
        • squeege
          • Feb 2007
          Debian + Zabbix How-To
          This might be helpful, seeing that Ubuntu is debian-based:
          Also, this is a more general unix + Zabbix how-to:
          http://howtoforge.net/zabbix_network_monitoring
          I am going to try installing Zabbix on Ubuntu 6.10 Server as a proof of concept, hopefully when 7.04 LTS arrives, I will it make a permanent solution.
          Good luck to you...
          • Rick-CK-STL
            • Feb 2007
            Newbie Looking for help and advice.
            I just installed Ubuntu 6.06 LAMP
            I'm trying to install zabbix and running into issues. I see from above I need to install some other packages with apt-get. I tried installing the list above, some go ok some fail.
            Does any one have a document for installing on Ubunto 6.06? I have read the other install docs but I think I need to work on the OS before I can start installing zabbix. Is Ubuntu a good distro to run zabbix on or should I be installing it on something else?
            Rick
