I couldn't find the answer explicitly in the docs so meybe here I will find it..
Normally, the trigger with "nodata" fucntion is calculated every 30 seconds.
How about the situtation, if the nodata function is in Recovery expression. Is it calulcated ONLY if the Trigger is in PROBLEM state or always, even if the trigger is OK?
Kind regards
Mariusz
Kind regards
Mariusz
