Apply compliance policy
  • mirddin
    • Nov 2013
    • 22
    Dears,
    Does anybody know if it's possible to apply compliance settings on network devices centrally using Zabbix (using snmpset, for example)? Take into account, there're no remote zabbix agents for sure.
  • kaspars.mednis
    • Oct 2017
    • 349
    The idea is to do some snmpset action based on trigger ?
    One possible way is to create an action, and in that action
    - specify trigger conditions for this action
    - in operations add operation Run remote commands on hosts, specify a custom script, and do whatever you want with snmpset
    best regards
    Kaspars
