Original EventID in Remote Command
  • Lemiluck
    • Oct 2017
    Hi there,
    if I create an action and choose under "Recovery operations" the operation Type "Send recovery message" the macro {EventID} returns the original EventID of the causing event in the email.
    Is there a way to get this value also for the operation Type "Remote Command"? If I use {EventID} there, it uses the ID of the solving event, and not the original one...
    Cheers,
    Lemi
  • Lemiluck
    • Oct 2017
    Wow, that went fast down :-)
    No one an idea how to get this original ID??
    • kaspars.mednis
      • Oct 2017
      • 349
      Which zabbix version are you using ?
      in zabbix 3.2 i can see following macros
      EVENT.ID} Numeric ID of the event that triggered an action.
      {EVENT.RECOVERY.ID} Numeric ID of the recovery event.
      Can be used in recovery messages only. Supported since 2.2.0.
      may be those can be used ?
      regards,
      Kaspars
      • Lemiluck
        • Oct 2017
        this value is what I'm searching for. But as writen in the documentation: "Can be used in recovery messages only", it only works when I'm sending a message. It doesn't get evaluated when I use it in "Remote Command" - it just stays {EVENT.RECOVERY.ID}.
        Regards,
        Lemi
