Can anybody shed any light on trigger dependancies?
If I have a router and a switch behind it, how does this work?
If I put a trigger dependency in so that the switch doesn't trigger due to the router being down, is there some some or delay so the switch doesn't trigger before the router?
eg the router is checked every minute but so is the switch. It would be possible for the switch to return (or not return a value before the router) which would then allow the switch to trigger?
