xinetd
  • mhammett
    • Jan 2007
    xinetd
    i just setup Zabbix. One of the triggers in the template is how many processes are running in inetd. My system uses xinetd. How do I change it to check that instead?
  • cbidwell
    • Aug 2006
    • 127
    I, too, am having the same problem. I try to create a new trigger such as:
    Name: xinetd is not running on {HOSTNAME}
    Expression: {Unix_t: proc.num[xinetd].last(0)}<1
    Severity: High
    and I get the result of:
    No such host (Unix_t) or monitored parameter (proc.num[xinetd])
    Any help would be greatly appreciated.
    • cptnzod
      • Jan 2007
      • 56
      I made the same thing under my host and not unix_t and it worked just fine.
      • James Wells
        • Jun 2005
        • 664
        Greetings,
        Did you paste this in directly from Zabbix? If so then the problem is that you have a space between the Unix_t: and proc.num.
        Unofficial Zabbix Developer
