Monitore a TP-Link AP on Zabbix
  • Bocar
    • Sep 2017
    • 23
    I have problem monitoring a TP-Link AP on Zabbix. I activated on my Zabbix server the Template SNMP Device on the host and it don't works... the read and set community on the TP-Link AP SNMP agent are set to public and private.
    Need a help.
  • allexpetrov
    • May 2017
    • 361
    There is no magic in zabbix, try to perform snmpwalk -v 2c -c public <ip> from server to that AP.
    Which output you have from this command?
    Regards,
    Alex!
    • Bocar
      • Sep 2017
      • 23
      Thank you Alex, it works now! i was a bit impatient... it makes time after host configuration before data pull up!
      Regards
      Bocar
