Maps, trigers dependency
  • marbo
    • Mar 2005
    I've 3 trigers on disk usage:
    1) free space < 20%
    2) free space < 10%
    3) free space < 5%
    1 depends on 2, and 2 depends on 3.
    And it works very well. When there is only 3% free space I can see only third triger raised but ... on map (where I'have this host) I can see 3 errors (from all 3 trigers) so it say that my free space is less than <20 % and < 10% and < 5%...
    It seems that triger dependecy does not work here.
    Has anybody similar problem? Is there any possiblity to force it to accept trigere dependency... or maybe any other idea
    BTW . I use 11 alpha6
    Regards
    marbo
  • marbo
    • Mar 2005
    nobody will answer ?
    nobody has silimar error ?
    M.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      The problem is not fixed yet. Thanks for reporting this!
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • bergziege
        • Dec 2007
        i experienced the same Problem as marbo does. I have got a Map with Links to Other Maps ( One MAP per Network). So if the Router is down i get alarms for each host on the Submap. to solve this i createt dependancies ang when watch the Triggers thi is Working very well. But On my Map i still get many Problems shown at the Map.
        i know this thread is a bit older but it discribes exactly what my problem is. So i think this has never been fixed until now. Or does somebody have a Workaround for this issue.
        B.T.W.: Using Zabbix 1.4.3
        regards
        bergziege
