Is it possible to remote command shows in zabbix history/mail
  • iftitutul
    • Sep 2017
    • 51
    I am using zabbix 3.4 and if trigger is generated like too many processes running on zabbix it will generates remote command and remote command shows in zabbix or zabbix history/latest data. Is it possible?
  • Pitons
    • Oct 2017
    • 49
    Hi iftitutul!
    Yes it is,
    You will find that info under: Reports -> Action log
    • iftitutul
      • Sep 2017
      • 51
      Thanks for swift response. Yes, I can see it whether mail sent or not and remote command shows executed or not. But my another requirement is:
      remote command result shows in zabbix mail body also
      • Pitons
        • Oct 2017
        • 49
        If I understand correctly you want to log command execution and result?
        One of the options is:
        1) create an item [Type: Zabbix trapper] for the command execution;
        2) create a script that executes what you need and uses zabbix_sender to return result to that item;
        3) you get what you asked for and you can go further creating triggers/actions based on that returned values.
