Zabbix Install Help
  • cardanid
    • Nov 2017
    Zabbix Install Help
    Hi, I am very new to Zabbix and the opensource world.
    I am trying to install Zabbix v3.4.3 Server into /apps instead of all the default locations. I have a few questions. Do to sever limits and company requirements, all application software should be installed in /apps. Using default Zabbix install directories will not work.
    1) To do this, I have to use the source (*.tar.gz) file instead of the RPM correct?
    2) When using the source file for install, the configure command fails at:
    checking for mysql_config... no
    configure: error: MySQL library not found
    Command used: /apps/vision/zabbix-server] # ./configure --prefix=/apps/vision/zabbix --enable-server --enable-agent --with-mysql --enable-java --enable-ipv6 --with-net-snmp --with-libcurl --with-libxml2
    I have mqsql already up and running on a different server with all the Zabbix requirements already complete. What am I missing on Zabbix Server host to get the install to work from the source?
    Also I have Zabbix already up and running via the rpm's, I am not having this issue and I can correct to the MySQL DB on the remote server.
    Zabbix will not be running as root, I have a account ID that Zabbix server will run under.
    yum list all |grep -i zabbix
    zabbix-agent.x86_64 3.4.0-1.el7 installed
    zabbix-java-gateway.x86_64 3.4.0-1.el7 installed
    zabbix-proxy-mysql.x86_64 3.4.0-1.el7 installed
    zabbix-server-mysql.x86_64 3.4.3-1.el7 installed
    zabbix-web.noarch 3.4.3-1.el7 installed
    zabbix-web-mysql.noarch 3.4.3-1.el7 installed
    pcp-export-zabbix-agent.x86_64 3.11.8-7.el7 prime-virt-rhel7
  • kaspars.mednis
    • Oct 2017
    • 349
    have you installed MySQL-devel package ? it may help...
    Regards,
    Kaspars
    • cardanid
      • Nov 2017
      Working but....
      Ok, I was missing a few dependencies that were needed on my newly built VM.
      I have Zabbix running from the source package and I have agents connecting. Now when I try to update the main dashboards widgets, The Edit widget comes up and just hangs.
      any thoughts?
