SSL on zabbix appliance
  • Ton
    • Oct 2017
    • 12
    I use Zabbix appliance 3.4.2. When i do a simple "a2enmod SSL". I get the errormessage: Error code: SSL_ERROR_RX_RECORD_TOO_LONG in firefox.
    This is without adding any certificates or additional configuration. For some reason i did get it working once under a self signed certificate once. But i restarted the appliance to get it working with an actual authenticated SSL certificate for (obviously) security. But for some reason i get stuck at this error.
    I think it might be an error in the appliance which i might have avoided the last time by dumb luck I have no clue at this point.
    The obvious google result tells you the fault lies somewhere that you are getting HTTP data over HTTPS. I can verify this by going to and getting a working page: "http://zabbix.internalnetwork.com:443/zabbix"
