zabbix dashboard Error in query
  • ibelieve
    • Nov 2017
    I just installed zabbix-server-mysql and zabbix-web-mysql ,the version is 3.4.3, i visited the zabbix frontend and there are many error on pages,
    Error in query [SELECT g.groupid,g.name FROM groups g WHERE EXISTS (SELECT NULL FROM hosts h,hosts_groups hg WHERE hg.hostid=h.hostid AND h.status='0' AND g.groupid=hg.groupid)] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'groups g WHERE EXISTS (SELECT NULL FROM hosts h,hosts_groups hg WHERE hg.hostid=' at line 1]
    This error should be the "groups" forgot to add backticks, the groups is mysql reserved words and needs to using backticks
    is it a bug ?
  • kaspars.mednis
    • Oct 2017
    • 349
    Hello !
    Which mysql version are you using ?
    Regards,
    Kaspars
    • ibelieve
      • Nov 2017
      Originally posted by kaspars.mednis
      Hello !
      Regards,
      Kaspars
      my mysql version is
      /usr/sbin/mysqld Ver 8.0.3-rc-log for Linux on x86_64 (MySQL Community Server (GPL))
      • kaspars.mednis
        • Oct 2017
        • 349
        MySQL 8.0.3 is not officially released yet, it's is a release candidate
        Sorry to say that, but MySQL 8 is not officially supported by zabbix at this moment.
        Are there any particualr reasons to use MySQL 8.0.3 ? Maybe you can use last stable version of MySQL 5.7 on this instance, and move to MySQL 8 as soon as it becomes officially released ?
        Regards,
        Kaspars
        • zabbixadmin_newbie
          • May 2018
          MySQL 8.0 has now been officially released but I am getting the same error when I access my frontend dashboard GUI. Any update to this thread?
