Zabbix Installation Concern
  • vnoc
    • Sep 2017
    • 115
    Hi Team,
    I have deployed Zabbix 3.2 version in one of the Redhat7.2.
    As 3.2 is the old version I tried to install 3.4 version by removing all the configuration files and restarting the server.
    And after that i tried to again started deploying Zabbix 3.4 ver but i am getting the below error .
    Error connecting to database: Access denied for user 'zabbix'@'localhost' (using password: YES)
    Please help me in fixing this as I am trying to fix this from last 2week which didn't work
  • allexpetrov
    • May 2017
    • 361
    As you can see - the error is that you can't connect to the database. Troubleshoot step Nr. one - check the zabbix_server.conf and fin the DBPassword. Try to connect to the database with the user and password specified in the config.
    Try something like this:
    mysql -uzabbix -p zabbix
    Regards,
    Aleksejs!
    • vnoc
      • Sep 2017
      • 115
      Tried it but it is not working getting below error
      ERROR 1045 (28000): Access denied for user 'zabbixuser'@'localhost' (using password: YES)
      And please find the zabbix_server.conf file attahced
      Below is the command
      mysql -uzabbixuser -p zabbixdb
      • allexpetrov
        • May 2017
        • 361
        Reset the password to the user or create another one. Also you can compare what you have in the config file with the one you have in the */etc/zabbix/web/zabbix.conf.php*
        There is no magic out there.
        Regards,
        Alex!
        • vnoc
          • Sep 2017
          • 115
          I changed the password but there is not luck .
          Can some one please help me. If possible can you ping me over skype
          akhilesh.y2 is my skypeid
          • kaspars.mednis
            • Oct 2017
            • 349
            You can try to connect to mysql as root, simply typing mysql in root console, then recreate zabbix user
            [root@zabbix ~]# mysql
            MariaDB [(none)]> drop user zabbix@localhost;
            Query OK, 0 rows affected (0.01 sec)
            MariaDB [(none)]> grant all privileges on zabbix.* to zabbix identified by '<password>';
            Query OK, 0 rows affected (0.00 sec)
            • vnoc
              • Sep 2017
              • 115
              All these steps were performed previously after which I have posted in the forum
              • allexpetrov
                • May 2017
                • 361
                Sorry, but in such case visit Zabbix Support page and ask professionals to help you. Your problem is the misconfiguration.
                Link: https://www.zabbix.com/services
                Or again - double check that you can connect to the mysql database from the Zabbix Server machine. Issue mysql -u<zabbixuser> -p <zabbixdbname> and if it is working, then open your server config file, change the DB* parameters and restart the Zabbix server.
                Please note: if you running DB on a different node, then your user needs to be like zabbix@<hostip/dns>, otherwise DB will drop your connection.
                Regards,
                Aleksejs!
                • Nehemoth
                  • Apr 2020
                  Regards,
                  Aleksejs!
                  Just registered here because the problem lies in the documentation
                  This is the command as per zabbix documentation
                  zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -p zabbix
                  The problem lies in the bold part above, everybody believes that the password should be there but of course it's not the password, is the database name that is expected, as @allexpetrov indicates previously.
                  What a waste of time in something so simple. Which waste of time I'm talking about the 'whole' internet with this issue.
                  The zabbix documentation should differentiate the user from the database name from the password instead of using the same zabbix name for everything.
                  Hope this help
