Cyberpower 201 SNMP Card Monitoring
  • jmcmahon113
    • Nov 2017
    Hello, new to zabbix. Trying to monitor my cyberpower UPS equipment, and zabbix is working great on RMCARD202 and RMCARD205 but the templates i have won't work with RMCARD201. I've been tyring every template i can get my hands on, and also trying to import MIBS to create my own Template but i fail each time.
    Does anyone have a good template for cyberpower on Zabbix 3.4?
  • Pitons
    • Oct 2017
    • 49
    Give us snmpwalk tree for that device, template which you are using now and name the things you want to monitor.
    • jmcmahon113
      • Nov 2017
      I'm not sure how to bring up a MIB tree for Zabbix. I am using Solarwinds right now, which is why i'm trying to migrate over to zabbix.
      From Solarwinds i'm trying to monitor OID : 1.3.6.1.4.1.3808.1.1.1.3.25 (upsAdvanceInputLineFailCause).
      • Pitons
        • Oct 2017
        • 49
        Run this from zabbix server:
        snmpwalk -v2c -c public [IP OF DEVICE]
        Replace public with snmp community
        Paste output to text file and attach to the post.
        • jmcmahon113
          • Nov 2017
          When i try to do the SNMP walk the response is (no Response from x.x.x.x)
          • Pitons
            • Oct 2017
            • 49
            If you cannot reach the device it's some network, firewall, misconfiguration problem. @first solve that it might be the root cause your templates not working.
