how to export graph data to pdf in zabbix 3.2.8
  • sphinx_ir
    • Nov 2017
    hi
    i using zabbix 3.2.8 and i want save graph data in pdf file to offer customers.
    for example, bandwidth rate graph usage for interfaces. Like prtg software
    best regards
  • Pitons
    • Oct 2017
    • 49
    There is no built in functionality for that.
    You have to use external tools via api or some scripting on the server side or modding frontend.
    But very basic and simple way would be installing some pdf printer and just printing the page from your browser.
    And then there is screenshots...
    • sphinx_ir
      • Nov 2017
      Is there a plugin or therth party app that can be used to do this?
      I want to access the graphs data whenever I need to, and provide it as a complete report to the customer. pdf printer and screen shot ,It's not the right solution for me
      Available scripts are not provided for this version of zabbix.
      You are guided me to use api
      Thanks for the feedback
      • Pitons
        • Oct 2017
        • 49
        Googled a bit - this came up:
        Contribute to kmpm/zabbix-dynamic-pdf-report development by creating an account on GitHub.
        Haven't tried myself but looks like could be useful to you.
        • sphinx_ir
          • Nov 2017
          Can the above links be used for zabbix 3.2.8
          • Pitons
            • Oct 2017
            • 49
            First one in readme states:
            Also to make sure it works 100% with Zabbix 3.0 (LTS)
            might work on 3.2
            For the second one.... read that tread, if you browse to last pages, you will see that posts are about 3.0 3.2 3.4 so - probably yes
            • ysus
              • Mar 2016
              • 104
              Google Chrome built-in "save to pdf" is not good enough?
              Or you need some kind of automated solution and create/save graphs on periodic basis?
