count does not work as I expect it to....
  • frater
    • Oct 2010
    • 340
    For years I've been using the item "packetloss" which I wrote myself.
    It works great and has helped me a lot finding the culprit of a bad internet experience.
    The triggers are set in a way that would give me info on a constant bad connection, but I found out that some connections just have a lot of packetloss for a short period of time.
    That's why I started counting the times I have 100% packetloss.
    It works partially...
    I'm getting the connections that have had 100% packetloss in the last hour, but that message does not go away after it has been OK for more than an hour.
    Anyone knows how that's possible??
    ITEM
    Name: Packetloss on $1
    Type: External check
    key: packetloss[{HOST.CONN}]
    Type: Numeric (unsigned)
    Units: %
    Update interval: 1m
    History: 180d
    Trend: 365d
    Trigger
    Site {HOST.CONN} has had 100% packetloss in the last hour
    {Template_Standalone:packetloss[{HOST.CONN}].count(1h,100)}>2
    Dependency: Template_Standalone: Site {HOST.CONN} has 100% packetloss (Internet down)
    Zabbix agents on Linux, FreeBSD, Windows, AVM-Fritz!box, DD-WRT and QNAP
  • frater
    • Oct 2010
    • 340
    I set the "OK Event Generation" to "None" never realizing that this would create such a situation.
    This trigger was the result of a clone from a trigger having a "Recovery Expression". Because that didn't apply to this trigger I set it to "None".
    This was wrong...
    Now I realize I had to set it to "Expression"
