Monitor recording of channels
  • stefanom
    • Oct 2016
    Hi
    I have a windows server which records tv channels. New file is created each hour with this naming: LIVE_BBC_WORLDNEWS_yyyy_mm_dd_hh.trp
    example:
    LIVE_BBC_WORLDNEWS_2017_11_20_13.trp
    LIVE_BBC_WORLDNEWS_2017_11_20_14.trp
    I want to be notified if the recording fails ----- i.e. next hour, new file not created.
    Any suggestions?
  • kaspars.mednis
    • Oct 2017
    • 349
    Just a few ideas
    Possible fast workaround - use vfs.dir.size and check the difference, no new file created - no changes to directory size
    Or use some custom windows powershell/batch/vbs/whatever script as UserParameter
    P.S
    here is some powershell solution for that https://social.technet.microsoft.com...our?forum=ITCG
