Zabbix graphs are missing text
  • moshikoy
    • Aug 2017
    • 56
    All my zabbix graphs are not showing a single character on them (see attachment)
    I suspect a font issue
    specs are: zabbix 3.4.1, installed on Ubuntu 1604 server
    - Moshe
  • moshikoy
    • Aug 2017
    • 56
    ehy, anyone can assist on this?
    • Atsushi
      • Aug 2013
      • 2028
      How did you install Zabbix?
      If you install using the package, that problem should not occur.
      Please check whether PHP supports TrueType and GD, and whether the display font in the graph is deployed.
      • moshikoy
        • Aug 2017
        • 56
        I've installed zabbix 3.4.1 from packages, on Ubuntu 16.04 LTS
        Using the below instructions
        Checking the PHP I can see that GD supports TrueType (see picture below)
        where else can I check?
        - Mosh
        • kloczek
          • Jun 2006
          • 1771
          If you will check php logs probably you will find that php cannot open/find font file.
          • moshikoy
            • Aug 2017
            • 56
            /var/log/apache2/error.log is empty
            checked php --info - and found nothing
            root@m:/# php --info | grep error -i
            display_errors => Off => Off
            display_startup_errors => Off => Off
            error_append_string => no value => no value
            error_log => no value => no value
            error_prepend_string => no value => no value
            error_reporting => 22527 => 22527
            html_errors => Off => Off
            ignore_repeated_errors => Off => Off
            log_errors => On => On
            log_errors_max_len => 1024 => 1024
            track_errors => Off => Off
            xmlrpc_error_number => 0 => 0
            xmlrpc_errors => Off => Off
            opcache.error_log => no value => no value
            • kloczek
              • Jun 2006
              • 1771
              In zabbix web frontend directory in fonts is DejaVuSans.ttf file.
              $ grep -r DejaVuSans *
              Binary file fonts/DejaVuSans.ttf matches
              include/defines.inc.php:define('ZBX_GRAPH_FONT_NAME',        'DejaVuSans'); // font file name
              Do you have this ttf file installed?
              • moshikoy
                • Aug 2017
                • 56
                Yes, I do
                root@server:~# fc-list | grep -i DejaVuSans
                /usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf: DejaVu Sans Mono:style=Book
                /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf: DejaVu Sans:style=Book
                /usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf: DejaVu Sans:style=Bold
                /usr/share/fonts/truetype/dejavu/DejaVuSansMono-Bold.ttf: DejaVu Sans Mono:style=Bold
                • kloczek
                  • Jun 2006
                  • 1771
                  So you are not aware of fact that web server is not able to read anything from outside document root base directory and this is why this font must be placed in web application directory tree?
