Inspect problems of disabled Hosts?
  • MondaySam
    • Nov 2017
    • 9
    Hey everyone,
    I have the following issue on our Zabbix 3.4.2:
    We have several hosts that are - for the moment - not available and therefore disabled in the Host Config.
    However, the ping triggers already created problems for this.
    My problem: Once the hosts are disabled, the corresponding problems are no longer displayed anywhere(?), so I cannot acknoledge and close them.
    This is an issue as we are using the API to monitor open problems and display the state (red for existing problems) on our dashboard.
    Is there a way to display these problems anywhere, or tell the Zabbix dashboad to not hide them?
    Thanks for any help!
  • registration_is_lame
    • Nov 2007
    • 148
    There is a filter under problems and Triggers page. Have you tried that?
    Choose History and you'll see old triggers. Scroll or select Date/week and you'll get the history.
    • MondaySam
      • Nov 2017
      • 9
      Thank you!
      EDIT:
      Well, not quite. If I disable a host, all its problems become hidden in the history too.
      Anyone an idea how to prevent or avoid this?
