I have problems with some Windows servers that do not give me Disk performance counters, while others do.
perf_counter["\LogicalDisk(_Total)\Disk Transfers/sec",300]
Half of my servers give 0, the second half is working perfectly.
I found that none of the Win 2012R2 are working, even if I tried to enable them:
diskperf -y (and reboot even if it says not to)
Create local performance counters, with the "Disk Transfers" counter and start them)
I still have 0
Any other had the same problem ?
I still have 0
