Hi to all!
Is it possible to run, easier as it possible, rebuild trends tables from exist history tables?
My case, in short, is like that:
Got disaster in original Zabbix-server storage ->
Restored Zabbix-server to very slow storage ->
Start to get every hour messages about "Zabbix-agent not available on host {HOST_NAME}" ->
Find that getting gaps in history (that why triggers is trigged) every hour ->
Find that problem is with DB speed on currents storage originally because having 1 file(ibdata1, size ~100GB) for the whole DB (legacy) ->
Start to kill history sync process that locks DB with disabling housekeep for keeping history ->
Now solved the problem with the storage(faster storage but lower than before) need to fill gaps in trends by using existing data from history.
After that will dump-restore database to mode "own file for single table"
My Zabbix is:
zabbix_server (Zabbix) 3.0.13
Revision 74336 7 November 2017, compilation time: Nov 23 2017 16:56:31
Used forum search before if duplicating, please give a link to the solution.
My Zabbix is:
